TwinTurbo.NET: Nissan 300ZX forum - Automatic transmission radiator specs needed
inferno
on May 17, 2008 at 10:58 AM
The stock radiator in a Z32 with an automatic transmission has two small pipes for inlet and outlet connections to the transmission. See
21606K
in the pic below. Does anybody know what the diameter of those pipes are?
Automatic transmission radiator specs needed -
inferno
10:58:38 05/17/08
Re: Automatic transmission radiator specs needed
txq45
11:21:24 05/17/08
Thanks for the info! The reason why I ask is because
inferno
11:52:50 05/17/08
5/16 is 7.93MM, that is closer to 8MM than 6MM
Fast300
00:49:33 05/18/08
There are two inlet options with the Derale trans cooler
inferno
06:31:26 05/19/08
OK, but the two small pipes on the radiator are still 8MM
Fast300
14:21:47 05/19/08
You are right. I did not phrase my question correctly
inferno
16:23:52 05/19/08
The 3/8 is close enough. (n/m)
Fast300
20:30:05 05/19/08
Thanks, I appreciate the feedback. (n/m)
inferno
03:58:38 05/20/08
